10년을 맥을 썼어도 모르는게 ㅜㅜ..도와주세요
박현규 7 7,312
얼마전 하드를 초기화시킨이후 제대로 않된건지 자꾸 문제가 발생하네요
프로그램 사용시 메모리가 자꾸 작다고 메세지가 뜨고요, 사용하다보면 맥os가 60메가에서 갑자기 150메가로 늘어나있기도 하고요, 그래서 또 메세지가 뜨거나 재시동하라 하고요,, 쿽도 자꾸 에러가 나구요ㅜㅜ
그리고 pc에서 가져온 eps,psd화일들이 용량이 크다며 않열려요,실상 10메가도 않되는데도요.
참고로 전 중고맥을 4년정도 사용했구요, G4에 시스템 9.2 메모리는 512입니다.
FASDFA
th). By <h2><b><a href="http://www.cartierreplicawatch.net/breitling-professional-b-1-steel-blue-mens-watch-a7836215-c5-874-replica-cartier.html">Breitling Professional B-1 Steel Blue Mens A7836215-C5-874 imitations</a></b></h2> subscribing to the gold <h3><b><a href="http://www.cartierreplicawatch.net">Cheap Cartier Watches</a></b></h3> plan the dealer needs to make just <h2><b><a href="http://www.lreplical.com">leather handbags on sale</a></b></h2> one additional sale per <h3><b><a href="http://www.lreplical.com/products/replica-chanel-35225-white-1384-bags.html">Chanel 35225-White-1384</a></b></h3> YEAR, to more than make up for the <h2><b><a href="http://www.ireplical.com/products/gucci-218513-bz0ug-8488-large-backpack-1881-handbags.html">Gucci 218513 BZ0UG 8488 large backpack-1881</a></b></h2> amount they would pay <h3><b><a href="http://www.ireplical.com">designer replica bags</a></b></h3> in that year. Any sale they make over <h2><b><a href="http://www.bestswissreplicas.com/breitling-replica-watches-aeromarine-replica-swiss-watches-941.html">replica Breitling Aeromarine Colt Oceane Diamond Steel Black Ladies A7738011-B7-617</a></b></h2> and above that one <h3><b><a href="http://www.bestswissreplicas.com/replica-swiss-watches-longines-clous-de-paris.html">Longines Clous De Paris</a></b></h3> sale would be a complete bonus. So, if <h2><b><a href="http://www.bestwatchesreplica.com/products/bvlgari-assioma-lady-bvlg-83-241-watch-replica.html">cheap Bvlgari Assioma Lady BVLG-83-241 watch replica</a></b></h2> you are a car <h3><b><a href="http://www.bestwatchesreplica.com/categories/ferrari-watches-replica.html">buy Ferrari watches</a></b></h3> dealer, what are you doing here? You should be <h2><b><a href="http://www.handbagdesigner.net">lv bags</a></b></h2> at www.UnoCarDealers.com now. You <h3><b><a href="http://www.handbagdesigner.net">cheap handbags</a></b></h3> will not believe that
내장메모리가 너무 많이 부족하시네요,
메모리 업글을 하셔야 될듯 합니다.
<내장 메모리대한 정보>
프로그램 실행아이콘을 정보입수(커맨드+i)해서 위에 메모리로 들어가신다음 사용메모리를 잡아주셔야 됩니다.
그래서 잘 사용하시려면 내장메모리를 1GB~1.5GB이상으로 올려주시는것이 좋습니다.(메모리가 부족하시면 구입해서 추가 하셔야 됩니다.)
내장메모리가 아무리 많아도 각각에 프로그램마다 사용메모리 수치를 올려주지 않으면 전혀 효과가 없습니다.
쿽3.3은 150MB이상
일러스트9,10는 200~300MB이상
포토샵6,7은 400MB~600MB이상(포토샵에서 큰데이타를 많이 열기 때문에 남은 메모리를 최대한 할당해 주시는것이 좋습니다.)
내장메모리에 여유가 많다면 더 많이 잡아주시고요.
대도록 포토샵에 많이 할당을 해주세요.
가상메모리는 끄세요.
G4라면 1GB~1.5GB이상을 권장합니다.(내장메모리)
자형폴더에 서체는 350종 이하로 사용하시는게 좋습니다.
내장메모리는 최소한 1GB이상 올려서 사용하심이 좋습니다. (가상메모리를 올려서 사용하면 작업속도가 저하됩니다. 정상적으로 내장메모리를 추가해서 사용하세요.) 그리고 램디스크는 절대 사용하지 마세요. 시스템 불안정의 원인이 됩니다.
맥사이트(A/S점/복구) 클릭후 (자기소개)클릭후 내용을 참조하세요...
emoticon_096 램디스크는 켜지 마세요.
현재 실제 메모리가 512MB로 적기 때문에 가상메모리만 좀 켜주어야 메모리를 좀더 효율적으로 사용이 가능합니다.
램디스크는 끄세요..
램디스크는 키면 안됩니다.
만약 가상메모리를 올려서 사용하시면 메모리를 뻥티기 해서 사용하는거라 작동은 가능하니 프로그램 속도는 많이 느려집니다.
가상메모리는 하드에 남은 공간을 메모리로 사용하는 거라 하드속도가 메모리보다 빠르지 않아서 작업이 느려지게 됩니다.
그렇기 때문에 가상메모리를 올려서 사용하는것 보다 메모리를 더 구입해서 올려주고 프로그램마다 사용메모리를 올려서 사용하는것이 좋습니다.
박현규
고맙습니다. 램디스크도 켜야 하나요?
emoticon_096 현재 맥 본체에 메모리가 많이 부족하십니다.
일단...
한글시스템 > 조절판의 메모리를 열고...가상메모리를 513메모리정도로 조정후에 재시동을 해주세요.
그리고 각 프로그램마다 메모리 할당을 다시 해준후에 사용을 하세요.
메모리는 본인맥에 설치된 전체메모리양과 주로 작업하는 프로그램과..그 프로그램에서 큰파일을 주로 다룬다면.. 해당프로그램에 넉넉히 할당을 해주는것입니다.
할당방법은
해당프로그램을 선택...정보입수(커맨드+I).. [일반]을 클릭..[메모리]를선택..
하단의 사용자 메모리에 메모리할당양을 입력..
1MB=1000으로 계산해서입력하세요(정확히는 1024Kbyte)
즉, 120MB= 120000을 입력하시면 됩니다.
