일러스트 9.0 저장이 안되네요!
일러스트 9.0 저장이 안되네요!
정경환 5 7,419
일러스트 9.0에서 저장을 하면 일러스트 저장이 안된다는 문구가 뜨네요
왜 그런지 아시는 분 있으시면 알려주세요
replica tiffany
es fiber <h2><b><a href="http://www.ebestwatch.com/products/omega-294.html">exact replica Omegamania Lady OMEG-85-671</a></b></h2> surface surrounded by are <h3><b><a href="http://www.ebestwatch.com/products/zenith-919.html">Zenith Defy Xtreme ZT-10-1015 imitation</a></b></h3> brushed outer ring replica <h4><b><a href="http://www.ebestwatch.com/products/patek-philippe-517.html">Patek Philippe Calatrava Automatic P_PHIL-79-801 imitation</a></b></h4> rado classic watches movado watches and are <h2><b><a href="http://www.ereplical.com">replica handbags</a></b></h2> calendar disc placed underneath <h3><b><a href="http://www.ereplical.com">handbags replica</a></b></h3> blued sapphire crystal inserts <h4><b><a href="http://www.ereplical.com/categories/louis-vuitton-monogram-dentelle-bags.html">Louis Vuitton Monogram Dentelle</a></b></h4> located at 6 oclock replica patek philippe <h2><b><a href="http://www.exactreplicas.net">exact replica</a></b></h2> replica patek philippe gondolo <h3><b><a href="http://www.exactreplicas.net/replica-hermes-paris-quartz-replica-watch-ladies-size-hems-a05.html">Hermes Paris Quartz replica. ( Ladies size )</a></b></h3> watches there s are <h4><b><a href="http://www.exactreplicas.net/replica-omega-de-ville-co-axial-chronograph-ladies-quartz-replica-watch-omde-a07.html">Omega De Ville Co-Axial Chronograph Ladies Quartz replica</a></b></h4> replica chanel small date aperture replica swiss <h2><b><a href="http://www.bestswissreplicas.com">swiss replica watches</a></b></h2> rolex datejust watches For <h3><b><a href="http://www.bestswissreplicas.com">replica watches</a></b></h3> optimal timelegibility under the <h4><b><a href="http://www.bestswissreplicas.com">replica watches</a></b></h4> sea surface the timepiece features square <h2><b><a href="http://www.bestwatchesreplica.com/products/breguet-lady-watch-br-16-74-watch-replica.html">cheap Breguet Lady BR-16-74 watch replica</a></b></h2> hour indices and sward <h3><b><a href="http://www.bestwatchesreplica.com/products/cartier-pasha-automatic-cart-47-298-watch-replica.html">cheap Cartier Pasha Automatic CART-47-298 watch replica</a></b></h3> replica rolex prince watches <h4><b><a href="http://www.bestwatchesreplica.com/products/cartier-pasha-calendar-cart-131-342-watch-replica.html">cheap Cartier Pasha Calendar CART-131-342 watch replica</a></b></h4> replica vacheron constantin shaped hour <h2><b><a href="http://www.handbagdesigner.net/chanel-handbags-designer-replica-handbags/replica-chanel-handbags-new-collection-designer/replica-chanel-handbag-16249-coffee-designer.html">Chanel handbag 16249-Coffee</a></b></h2> and minutes hands with <h3><b><a href="http://www.handbagdesigner.net/brand_dir/replica-chloe-handbags-wallets-designer">Chloe handbags Wallets knockoffs</a></b></h3> luminescent coating At the <h4><b><a href="http://www.handbagdesigner.net/brand_dir/replica-louis-vuitton-wallets-monogram-canvas-designer">Louis Vuitton Wallets Monogram Canvas</a></b></h4> heart of patek philippe replica bell ross wa
정경환
emoticon_096 한글시스템 >Preferences폴더에서 일러스트 프리퍼런스 파일을 삭제하고..
현재 일러스트 프로그램도 지우세요.
그리고.
일러스트 설치프로그램으로 재설치를 해주고 사용을 해보세요.
이렇게 재설치후에 증상이 사라지는 경우도 종종 있습니다.
OSCD로부팅후 디스크퍼스트애드로 하드점검을 해보세요. 그래도 해결이 안되면 하드 재포맷해서 사용하셔야 됩니다.
맥사이트(A/S점,복구) 클릭후 (자기소개)클릭후 내용을 참조하세요.
자주 보는 현상인데요.
가장 많은 경우가 하드디스크에 포맷상태나 볼륨상태가 안좋아서 저장이 안되는 경우 입니다.
이런경우 하드디스크복구를 하거나 포맷을 하셔야 됩니다.
디스크복구는 OS 9시디로 부팅을 해서 disk first aid로 복구를 해보는 방법이 있지만 복구 능력이 약해서 별 도움이 안되는 경우가 많습니다.
그래서 최소 OS X(10)시디로 부팅을 해서 메뉴에 디스크유틸리티로 디스크복구를 해보거나 외장으로 부팅을 해서 전문적인 유틸리티를 이용해봐야 됩니다.
아니면 한번쯤 하드 포맷이 필요한 시점이고요.
