맥에서 화면재생빈도를
맥에서 화면재생빈도를
sunday
주변
4
5,197
2010.02.04 10:18
맥에서 화면재생빈도를 높이려고하는데요 어디로 들어가야 하나요?
자세히좀 알려주세요.
(화면재생빈도를 높여주면 화면떨림이 좀 나아진다고 해서요...)
한번 해보려구요
replica watches
2010.04.03 16:49
everything goes <h2><b><a href="
http://www.omegareplicawatch.net/roger-dubuis-replica-omega.html"
>imitation Roger Dubuis watches</a></b></h2> smoothly; Dealing directly with <h3><b><a href="
http://www.omegareplicawatch.net/omega-double-eagle-perpetual-calendar-mens-watch-1213-10-replica.html"
>Omega Double Eagle Perpetual Calendar Mens 1213.10</a></b></h3> the manufact <h4><b><a href="
http://www.omegareplicawatch.net/hublot-big-bang-mens-watch-301-ai-460-rx-replica.html"
>Hublot Big Bang Mens 301.AI.460.RX</a></b></h4> urer can <h2><b><a href="
http://www.onreplicas.com/ah-replica-handbags"
>cheap AH sale</a></b></h2> reduce the lag time <h3><b><a href="
http://www.onreplicas.com"
>knockoffs-handbag</a></b></h3> (and often also the <h4><b><a href="
>quality-handbag</a></b></h4> price!), versus dealing <h2><b><a href="
http://www.handbagsfake.com/fake-gucci-bags"
>fake Gucci bags</a></b></h2> with a broker; Choose <h3><b><a href="
http://www.handbagsfake.com"
>cheap fake Handbags</a></b></h3> a replicator who is <h4><b><a href="
http://www.enreplicas.com/replica-louis-vuitton-handbags/suhali-leather/suhali-leather-le-fabuleux-white-m91815.html"
>Suhali Leather Le Fabuleux White M91815</a></b></h4> accessible. Are <h2><b><a href="
http://www.bestswissreplicas.com/replica-baume-mercier-watches-swiss.html"
>Baume & Mercier watches for sale</a></b></h2> they always there when <h3><b><a href="
http://www.bestswissreplicas.com"
>replica watches</a></b></h3> you need them? Can <h4><b><a href="
>replica watches</a></b></h4> you trust your <h2><b><a href="
http://www.bestwatchesreplica.com"
>watches replica</a></b></h2> project in their hands? <h3><b><a href="
>watch replica</a></b></h3> Do they care about <h4><b><a href="
>best watch replica</a></b></h4> your project? Test <h2><b><a href="
http://www.cartierreplicawatch.net"
>Cartier Replica Watches</a></b></h2> and re-test your master <h3><b><a href="
http://www.cartierreplicawatch.net/longines-evidenza-mens-watch-l2-642-8-51-2-replica-cartier.html"
>Longines Evidenza Mens L2.642.8.51.2</a></b></h3> for errors. Theres nothing <h4><b><a href="
http://www.cartierreplicawatch.net/replica-vacheron-constantin-watch-cartier.html"
>Vacheron Constantin Imitations</a></b></h4>
everything goes <h2><b><a href="http://www.omegareplicawatch.net/roger-dubuis-replica-omega.html">imitation Roger Dubuis watches</a></b></h2> smoothly; Dealing directly with <h3><b><a href="http://www.omegareplicawatch.net/omega-double-eagle-perpetual-calendar-mens-watch-1213-10-replica.html">Omega Double Eagle Perpetual Calendar Mens 1213.10</a></b></h3> the manufact <h4><b><a href="http://www.omegareplicawatch.net/hublot-big-bang-mens-watch-301-ai-460-rx-replica.html">Hublot Big Bang Mens 301.AI.460.RX</a></b></h4> urer can <h2><b><a href="http://www.onreplicas.com/ah-replica-handbags">cheap AH sale</a></b></h2> reduce the lag time <h3><b><a href="http://www.onreplicas.com">knockoffs-handbag</a></b></h3> (and often also the <h4><b><a href="http://www.onreplicas.com">quality-handbag</a></b></h4> price!), versus dealing <h2><b><a href="http://www.handbagsfake.com/fake-gucci-bags">fake Gucci bags</a></b></h2> with a broker; Choose <h3><b><a href="http://www.handbagsfake.com">cheap fake Handbags</a></b></h3> a replicator who is <h4><b><a href="http://www.enreplicas.com/replica-louis-vuitton-handbags/suhali-leather/suhali-leather-le-fabuleux-white-m91815.html">Suhali Leather Le Fabuleux White M91815</a></b></h4> accessible. Are <h2><b><a href="http://www.bestswissreplicas.com/replica-baume-mercier-watches-swiss.html">Baume & Mercier watches for sale</a></b></h2> they always there when <h3><b><a href="http://www.bestswissreplicas.com">replica watches</a></b></h3> you need them? Can <h4><b><a href="http://www.bestswissreplicas.com">replica watches</a></b></h4> you trust your <h2><b><a href="http://www.bestwatchesreplica.com">watches replica</a></b></h2> project in their hands? <h3><b><a href="http://www.bestwatchesreplica.com">watch replica</a></b></h3> Do they care about <h4><b><a href="http://www.bestwatchesreplica.com">best watch replica</a></b></h4> your project? Test <h2><b><a href="http://www.cartierreplicawatch.net">Cartier Replica Watches</a></b></h2> and re-test your master <h3><b><a href="http://www.cartierreplicawatch.net/longines-evidenza-mens-watch-l2-642-8-51-2-replica-cartier.html">Longines Evidenza Mens L2.642.8.51.2</a></b></h3> for errors. Theres nothing <h4><b><a href="http://www.cartierreplicawatch.net/replica-vacheron-constantin-watch-cartier.html">Vacheron Constantin Imitations</a></b></h4>
2010.02.04 10:33
해상도를 높여주던가 변경하시려면 OS9 환경인 경우엔 조절판의 모니터환경에서 조정해 주시면 되고,OSX환경에서는 시스템환경설정/모니터환경에서 조정해 주시면됩니다.
해상도를 높여주던가 변경하시려면 OS9 환경인 경우엔 조절판의 모니터환경에서 조정해 주시면 되고,OSX환경에서는 시스템환경설정/모니터환경에서 조정해 주시면됩니다. ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ 맥사이트(A/S점/복구) 클릭후 (자기소개)클릭후 내용을 참조하세요..
2010.02.04 10:30
OS버전과 맥기종및 어떤 모니터인지(CRT인지 LCD인지)를 알아야 설명이 가능합니다.
OS버전과 맥기종및 어떤 모니터인지(CRT인지 LCD인지)를 알아야 설명이 가능합니다. ================= A/S가 필요하시면 베스트맥(A/S,판매)를 클릭하고 자기소개를 참고하세요
2010.02.04 10:24
emoticon_096 MacOS9라면..
한글시스템 > 조절판의 모니터를 열고 조정을 하시면 됩니다
MacOS X에서는 애플메뉴의 [시스템 환경설정]을 열고..
[모니터]를 클릭후 조정을 해주세요.
emoticon_096 MacOS9라면.. 한글시스템 > 조절판의 모니터를 열고 조정을 하시면 됩니다 MacOS X에서는 애플메뉴의 [시스템 환경설정]을 열고.. [모니터]를 클릭후 조정을 해주세요. ========= ▷▶☎ 잘 해결이 안되신다면.. 준[A/S 판매]를 클릭후 <자기 소개>를 마우스로 눌러보세요.
76 명
2,202 명
3,051 명
14,786,225 명
