G3와 G4의 차이점 알려주시길...
coffee 4 6,183
안녕하세요? 파워맥에서 인터넷하려다 포기했었거든요. 그래서 G3나 G4 350~400MHZ를 구입하려고 하는데 인터넷쓰면 G4 1.25MHZ랑 어떤 차이가 있나요? 어디서해보니 G4 1.25MHZ 로 인터넷을 쓰니 어느 정도 괜찮든데요. 속도나 익스플로러인스톨 등등 G4 1.25 Mhz처럼 G4(400)나 G3도 익스플로러 인스톨이 자동인가요? 일할때 음악듣는것을 좋아하는데 iTunes도 사용가능한가요? 가능한 토스트프로그램이나 버전은요? 속도차이가 어느정도인지 램은 어느정도가 적당한지요? 사진작업이 많거든요~ 아시는분의 리플부탁합니다~~~~
discount replic…
u considering <h2><b><a href="http://www.bagsshop.net/louis-vuitton-handbags-replica-handbags/lv-damier-canvas/louis-vuitton-handbags-n51286-sarria-mini.html">cheap Louis Vuitton Handbags N51286-Sarria Mini</a></b></h2> well, for selecting the <h3><b><a href="http://www.bagsshop.net">replica bags
</a></b></h3> pertinent action is prerequisite <h4><b><a href="http://www.bagsshop.net">designer replica handbags
</a></b></h4> besides not little. irrefutable provides <h2><b><a href="http://www.hot-handbags.com">cheap fendi handbags</a></b></h2> a low panorama of <h3><b><a href="http://www.hot-handbags.com">cheap louis vittion Handbags</a></b></h3> Anna Corinna bags besides <h4><b><a href="http://www.hot-handbags.com">replica handbags</a></b></h4> serves you eclipse room also liveliness. If you are <h2><b><a href="http://www.replicawatchesbrands.com/replica-omega-constellation-double-eagle-steel-black-mens-watch-1519-51/">replica Omega Constellation Double Eagle Steel Black Mens 1519.51</a></b></h2> the apart who is <h3><b><a href="http://www.replicawatchesbrands.com/replica-bedat-no-3-steel-black-mens-watch-388-010-101/">Bedat No. 3 Steel Black Mens 388.010.101</a></b></h3> not jumpy of receiving <h4><b><a href="http://www.replicawatchesbrands.com/replica-longines-evidenza-mens-watch-l2-642-8-51-2/">cheap Longines Evidenza Mens L2.642.8.51.2 on sale</a></b></h4> immeasurably attention, Anna Corinna movement commit definitely <h2><b><a href="http://www.handbagdesigner.net">replica handbags</a></b></h2> captivate the folks around <h3><b><a href="http://www.handbagdesigner.net">designer handbags for cheap</a></b></h3> you and rack up <h4><b><a href="http://www.handbagdesigner.net/brand_dir/replica-bottega-veneta-handbags-bottega-veneta-handbags-designer">Bottega Veneta handbags Bottega Veneta handbags knockoffs</a></b></h4> lots of praises. Nobody commit be pleased to glom whereas <h2><b><a href="http://www.uggbootssaleonline.co.uk">discount uggs outlet</a></b></h2> matchless job influence a <h3><b><a href="http://www.uggbootssaleonline.co.uk">ugg boots sale</a></b></h3> trivial carry on a <h4><b><a href="http://www.uggbootssaleonline.co.uk/products/chestnut-ugg-new-arrival-5389-outlet.html">discount Chestnut UGG New Arrival 5389</a></b></h4> snowed alacrity morning, am I apropos? At foremost smooch <h2><b><a href="http://www.replicachanelearrings.com">chanel earrings</a></b></h2> of Anna Corinna stead <h3><b><a href="http://www.replicachanelearrings.com">replica chanel jewelry</a></b></h3> tote, you will be versed evident is a profitable plan. fling y
끝까지 읽어주셨군요.
오히려 제가 고맙네요. ^^
coffee
많은 도움을 주셔서 감사합니다. (^__^)
속도는 물론 많은 차이가 납니다.
작업 속도는 물론 인터넷 서핑시 로딩 속도 또한 많은 차이가 납니다.
익스플로러나 iTunes는 Mac OS인 한글 시스템을 설치하면 자동으로 설치가 됩니다.
한글 시스템의 버젼은 9.2.2를 사용하시는 것이 좋으며, 메모리는 사진 작업이 많으시다니 1GB 이상을 사용하시는 것이 좋을 것입니다.
인터넷 서핑이나 동영상 감상에 있어서는 OS X이 훨씬 유리하므로 OS X을 사용하시는 것도 고려를 해보시는 것이 좋을 듯하네요.
G4/1.25와 G4/400을 비교하는 것은 무리가 있습니다.
두 기종간의 성능 차이가 크기 때문입니다.
당연히 구입 예산과 성능을 고려하여 구입을 결정하셔야 하겠지만, 성능면에 중점을 두신다면 G4/733 이상의 기종을 구입하시는 것이 좋을 듯합니다.
물론 G4/350, 400도 작업은 가능하지만 작업 속도나 인터넷 서핑 속도에서는 분명 차이가 있답니다.
그리고 토스트 프로그램은 5.대를 사용하시는 것이 좋을 것이구요.
도움이 되었는지 모르겠네요.
