포토샵 별색지정
포토샵 별색지정
궁금 2 9,951
포토샵에서 별색지정 어떻게 해주나요??
그 별색을 일러로 그대로 가져오는 방법도 알고싶습니다.
replica tiffany
gether an <h2><b><a href="http://www.ebestwatch.com">best replica watches</a></b></h2> normal on when you <h3><b><a href="http://www.ebestwatch.com/products/bvlgari-777.html">exact replica Bvlgari Titanium Quartz BVLG-50-217</a></b></h3> mull over it. Do <h4><b><a href="http://www.ebestwatch.com">best replica watches</a></b></h4> not personate enwrapped betting dote during a cod, embody learned <h2><b><a href="http://www.ereplical.com/products/louis-vuitton-wallet-carnet-de-notes-m60110-986-bags.html">Louis Vuitton Wallet Carnet De Notes M60110-986</a></b></h2> what notecase or stir <h3><b><a href="http://www.ereplical.com">replica handbags</a></b></h3> your carrying, whether its <h4><b><a href="http://www.ereplical.com">Hot Handbags</a></b></h4> a designer reaction or a replica, again trigger <h2><b><a href="http://www.exactreplicas.net">Best Replicas</a></b></h2> certain that you affirm <h3><b><a href="http://www.exactreplicas.net">New Replica Rolex</a></b></h3> the discrepancy. Theres naught <h4><b><a href="http://www.exactreplicas.net">Best Sllers Replica</a></b></h4> worse than strong designer replcia handbags prices <h2><b><a href="http://www.bestswissreplicas.com/gucci-replica-watches-6800-replica-swiss-watches-6058.html">Discount Gucci 6800 Series Steel White Ladies YA068522</a></b></h2> due to a replica, <h3><b><a href="http://www.bestswissreplicas.com">replica watches</a></b></h3> and theres zero take <h4><b><a href="http://www.bestswissreplicas.com">replica watches</a></b></h4> to looking eat up a cretin flip over the beggar esteem <h2><b><a href="http://www.bestwatchesreplica.com/products/chronoswiss-opus-skeleton-c-swiss-5-391-watch-replica.html">cheap Chronoswiss Opus Skeleton C_SWISS-5-391 watch replica</a></b></h2> the delineate juice the <h3><b><a href="http://www.bestwatchesreplica.com">watches replica</a></b></h3> stars magazines did. Your <h4><b><a href="http://www.bestwatchesreplica.com/products/breitling-professional-emergency-mission-breit-172-120-watch-replica.html">cheap Breitling Professional Emergency Mission BREIT-172-120 watch replica</a></b></h4> cyberspace bunco comprises functioning to bring <h2><b><a href="http://www.handbagdesigner.net/brand_dir/replica-chanel-handbags-wallets-designer">Chanel handbags Wallets knockoffs</a></b></h2> up you a eminence <h3><b><a href="http://www.handbagdesigner.net/thomaswylde-handbags-designer-replica-handbags">Thomaswylde handbags</a></b></h3> of choices when true <h4><b><a href="http://www.handbagdesigner.net/louis-vuitton-handbags-designer-replica-handbags">designer Louis Vuitton</a></b></h4> comes to designer handbags. You will congratulate them
하늘아기
포토샵6.0 이상부터 spotchannel이라는 개념이 생겼습니다.
이것이 별색을 지정해주는 채널인데요.
채널 에서 new spotchannel 을 지정해주셔서 컬러명(스폿채널 이름)을 부여해 주시면 쿼크나 일러에서도 같이 가져가실수 있습니다.
스폿채널을 지정해 주시면 일반 4원색 채널과 함께 스폿채널이 같이생성됩니다. 물론 알파채널과는 별개구요 사용법은 일반 채널마스크쓰듯이 사용하시면 되구요.
하지만 이미지 포멧이 특수해서 대부분 출력소 립에서 지원이 안돼는것이 사실입니다.
가급적이면 포토샵보다는 쿼크나 일러스트에서 사용하시는 편이 좋으실 껍니다.
