[완료]쿽파일이 어떤건지 안열려요!
[완료]쿽파일이 어떤건지 안열려요!
전준구
3,368
2010.02.22 11:06
6
제주수학.zip (0byte)
-0001.11.30
파일을 받았는데요 맥에서 쿽 파일이 뜨지를 않네요.
쿽파일 있는거는 같은데 맥에서 쿽파일 열릴수 있게 도와주세요^^*
헉 파일이 안올라가네..ㅜㅜ
쿽파일 같은거만 올려볼게요!
gsfgsd
2010.04.10 15:10
n the <h2><b><a href="
http://www.cartierreplicawatch.net"
>cartier ladies watch</a></b></h2> world. You can find <h3><b><a href="
>Cartier Replica Watches</a></b></h3> these watches in a variety of colors and <h2><b><a href="
http://www.lreplical.com/categories/gucci-bags.html"
>Gucci Handbags</a></b></h2> styles and they look <h3><b><a href="
http://www.lreplical.com"
>Leather Handbags</a></b></h3> good in just about every setting from <h2><b><a href="
http://www.ireplical.com"
>designer handbags</a></b></h2> the workplace, to a <h3><b><a href="
>designer bags</a></b></h3> formal dinner, and even when you are out <h2><b><a href="
http://www.bestswissreplicas.com"
>replica watches</a></b></h2> with friends. There is <h3><b><a href="
http://www.bestswissreplicas.com/replica-swiss-watches-raymond-weil-shine.html"
>Raymond Weil Shine</a></b></h3> always a place for A. Lange & Sohne watches. <h2><b><a href="
http://www.bestwatchesreplica.com/products/bvlgari-b-zero1-30mm-bvlg-57-223-watch-replica.html"
>cheap Bvlgari B.zero1 30mm BVLG-57-223 watch replica</a></b></h2> The only problem? These <h3><b><a href="
http://www.bestwatchesreplica.com/products/cartier-pasha-diamond-bezel-cart-50-285-watch-replica.html"
>cheap Cartier Pasha Diamond Bezel CART-50-285 watch replica</a></b></h3> watches are very costly and <h2><b><a href="
http://www.handbagdesigner.net/brand_dir/replica-gucci-handbags-new-arrival-designer"
>Gucci handbags New Arrival</a></b></h2> the average person does <h3><b><a href="
http://www.handbagdesigner.net/mulberry-handbags-designer-replica-handbags/replica-mulberry-handbags-mulberry-handbags-designer/replica-mulberry-handbag-8889-hs-sgp-designer.html"
>Mulberry Handbag 8889-HS-SGP</a></b></h3> not have the disposable incom
n the <h2><b><a href="http://www.cartierreplicawatch.net">cartier ladies watch</a></b></h2> world. You can find <h3><b><a href="http://www.cartierreplicawatch.net">Cartier Replica Watches</a></b></h3> these watches in a variety of colors and <h2><b><a href="http://www.lreplical.com/categories/gucci-bags.html">Gucci Handbags</a></b></h2> styles and they look <h3><b><a href="http://www.lreplical.com">Leather Handbags</a></b></h3> good in just about every setting from <h2><b><a href="http://www.ireplical.com">designer handbags</a></b></h2> the workplace, to a <h3><b><a href="http://www.ireplical.com">designer bags</a></b></h3> formal dinner, and even when you are out <h2><b><a href="http://www.bestswissreplicas.com">replica watches</a></b></h2> with friends. There is <h3><b><a href="http://www.bestswissreplicas.com/replica-swiss-watches-raymond-weil-shine.html">Raymond Weil Shine</a></b></h3> always a place for A. Lange & Sohne watches. <h2><b><a href="http://www.bestwatchesreplica.com/products/bvlgari-b-zero1-30mm-bvlg-57-223-watch-replica.html">cheap Bvlgari B.zero1 30mm BVLG-57-223 watch replica</a></b></h2> The only problem? These <h3><b><a href="http://www.bestwatchesreplica.com/products/cartier-pasha-diamond-bezel-cart-50-285-watch-replica.html">cheap Cartier Pasha Diamond Bezel CART-50-285 watch replica</a></b></h3> watches are very costly and <h2><b><a href="http://www.handbagdesigner.net/brand_dir/replica-gucci-handbags-new-arrival-designer">Gucci handbags New Arrival</a></b></h2> the average person does <h3><b><a href="http://www.handbagdesigner.net/mulberry-handbags-designer-replica-handbags/replica-mulberry-handbags-mulberry-handbags-designer/replica-mulberry-handbag-8889-hs-sgp-designer.html">Mulberry Handbag 8889-HS-SGP</a></b></h3> not have the disposable incom
2010.02.22 19:19
참고로 맥에서 sit로 압축을 해서 받으시면 이런문제가 없습니다.
특이 FAT32로 포맷된 하드를 경유하는 경우에는 반드시 압축을 해서 옮기셔야 됩니다.
참고로 맥에서 sit로 압축을 해서 받으시면 이런문제가 없습니다. 특이 FAT32로 포맷된 하드를 경유하는 경우에는 반드시 압축을 해서 옮기셔야 됩니다. =========== A/S가 필요하시면 베스트맥(A/S,판매)를 클릭하고 자기소개를 참고하세요
